标题: CAT28C512 Programming failed! [打印本页]
作者: Jason    时间: 2021-7-19 22:50     标题: CAT28C512 Programming failed!
How can TL866II plus program CAT28C512? I tried 4 pieces of CAT28C512, all failed, and the result was the same as the picture.
Steps:
1. open a file and try to write to CAT28C512, the verification failed;
2. Read the content of CAT28C512, and found no change as before programming.
图片附件: [1.write] write_failed.jpg (2021-7-19 22:43, 323.98 KB) / 下载次数 23191
http://forums.xgecu.com/attachment.php?aid=766&k=ba1b0f928ea9ebed70ebe41a03ea1c52&t=1793248814&sid=Im29Eg
图片附件: [2.verify] read_verify.jpg (2021-7-19 22:43, 319.19 KB) / 下载次数 23343
http://forums.xgecu.com/attachment.php?aid=767&k=9216663411afbedfa3a20cd6190add9c&t=1793248814&sid=Im29Eg
作者: admin    时间: 2021-8-23 08:32
回复 1# Jason
会进行测试
作者: admin    时间: 2021-8-29 14:57
升级到11.20 ,11.10有个写保护问题
在11.20测试了,只是引脚检查功能错误,忽略一下就可以了,编程没有问题的,
下个版本修正引脚检查的问题:
TL866II
T56:
图片附件: 28C512.png (2021-8-29 14:56, 46.93 KB) / 下载次数 20162
http://forums.xgecu.com/attachment.php?aid=914&k=409000f81676286a6979d6f2e2690fe7&t=1793248814&sid=Im29Eg
图片附件: 28C512T56.png (2021-8-29 14:59, 45.08 KB) / 下载次数 20188
http://forums.xgecu.com/attachment.php?aid=915&k=7f08f9901e2b05518dde6a081ceeb339&t=1793248814&sid=Im29Eg
