标题:
Programming AT27C040 Failure ?
[打印本页]
作者:
koala
时间:
2021-6-22 13:21
标题:
APP Version : 11.00 Model : TL866II Plus
Device : AT27C040 @PLCC32
Pins Detected Passed!
ID: 0x 1E 0B ......OK!
Programming FLASH ...Succeeded. Time : 2031ms
Verifing FLASH ...
ERROR! CODE Address:0x00061E Buf_Val:0x45 IC_Val:0x44
Programming ...Failed
作者:
时间:
2021-6-22 16:09
koala
this a one-time programmable
read-only memory (OTP EPROM)
only blank chip can be programmed.
作者:
koala
时间:
2021-6-23 15:34
Correct as AT29C040A-90JU FLASH MEMORY
Powered by Discuz! 7.2
