标题: New Logic Test - 7419 Vector Table [打印本页]
作者: yovish    时间: 2021-5-22 04:05     标题: New Logic Test - 7419 Vector Table
The test was performed on the M74LS19P (hex Schmitt-Trigger inverters) chip from Mitsubishi.
图片附件: 7419 - Logic Vector.jpg (2021-5-22 04:04, 214.83 KB) / 下载次数 23581
http://forums.xgecu.com/attachment.php?aid=557&k=3da592c0a18408b201d4faebcce8fb0d&t=1793814700&sid=6YZU6s
图片附件: 7419 - Logic Test.jpg (2021-5-22 04:05, 257.78 KB) / 下载次数 23868
http://forums.xgecu.com/attachment.php?aid=558&k=98675fe6c60d07719cda683048e4db34&t=1793814700&sid=6YZU6s
图片附件: M74LS19P.jpg (2021-5-22 04:05, 315.72 KB) / 下载次数 24393
http://forums.xgecu.com/attachment.php?aid=559&k=2c916f2e74c2650755cd8106cd61cf22&t=1793814700&sid=6YZU6s
附件: SN74LS19A, SN74LS24A.pdf (2021-5-22 04:05, 1.12 MB) / 下载次数 27723
http://forums.xgecu.com/attachment.php?aid=560&k=4afbc8d972f4c52f8a289268329885fa&t=1793814700&sid=6YZU6s
附件: 7419.lgc (2021-5-22 04:05, 2.11 KB) / 下载次数 101699
http://forums.xgecu.com/attachment.php?aid=561&k=b2579924b6dde6a6bf01aa9346e19085&t=1793814700&sid=6YZU6s
作者: admin    时间: 2021-5-22 09:22
回复 1# yovish
Thank you for your hard work.
It is recommended to add more vector test lines to detect short circuits between two adjacent logic cells.
As shown below:
图片附件: 阿里旺旺图片20210522092912.jpg (2021-5-22 09:22, 33.18 KB) / 下载次数 22031
http://forums.xgecu.com/attachment.php?aid=568&k=270f5f8c556a69065f85ee9358fdf8ee&t=1793814700&sid=6YZU6s
作者: yovish    时间: 2021-5-22 19:04
It would be best to test all possible combinations of inputs and outputs on 6 gates (2^6=64), but I thought that's what you wanted, example of similar tests: 4009, 4069, 4584, 7404, 7405*, 7406*, 7414, 7416...
Creating tests with lots of lines is a pain in this release and you ignore various suggestions for improving the software ...
I am a supporter of full tests, but it seemed to me that it is about initial tests of the logic of the integrated circuit, and everyone can write exact and more precise tests by themselves.
Yes, otherwise I am attaching a full test of the 7419 (it can also be used for other integrated circuits of the same design)...
图片附件: 7419 (Full test) - Logic Vector.jpg (2021-5-22 19:03, 643.65 KB) / 下载次数 27736
http://forums.xgecu.com/attachment.php?aid=569&k=4561559106844cd706b481b194fd147c&t=1793814700&sid=6YZU6s
图片附件: 7419 (Full test) - Logic Test.jpg (2021-5-22 19:03, 302 KB) / 下载次数 24394
http://forums.xgecu.com/attachment.php?aid=570&k=ad22e25d09c13c24c0760ab0ecfb705d&t=1793814700&sid=6YZU6s
附件: 7419 (Full test).lgc (2021-5-22 19:04, 3.56 KB) / 下载次数 103121
http://forums.xgecu.com/attachment.php?aid=571&k=e9fc3aa217b7c517049c34c9b8f47f01&t=1793814700&sid=6YZU6s
作者: admin    时间: 2021-5-23 10:04
回复 3# yovish
Yes, it is a lot of work to perform all the combined tests. Generally,  only the logic combination test of nearby pins is required..
