标题: microwire eeprom (AT59C11, OKI 16911G, GI5911 and compatibles) [打印本页]
作者: wLLm    时间: 2021-5-18 20:52     标题: microwire eeprom (AT59C11, OKI 16911G, GI5911 and compatibles)
I need to program some OKI16911G/compatibles chips. They are similar to 93c46 but different opcodes so I think this should be easy to implement.
https://pdf1.alldatasheet.com/da ... 8/OKI/MSM16911.html
https://pdf1.alldatasheet.com/da ... /ATMEL/AT59C11.html
Thanks!
Regards,
William
作者: wLLm    时间: 2021-5-27 20:23
Bump, any update on this?
作者: admin    时间: 2021-5-28 10:22
回复 2# wLLm
   Please wait, mark it,  will be added in the future
作者: wLLm    时间: 2021-7-5 07:13
I see that OKI 16911G and compatibles has been added for T56. Will this be added too for the TL866II plus?
作者: wLLm    时间: 2021-7-22 06:06
回复  wLLm
admin 发表于 2021-5-28 10:22
I bought the T56 to program the OKI16911G but writing doesn't work, if I write 0xFD during verify it reads 0xFF.  I tried a TS59C11 which is OKI16911/AT59C11 compatible but with the same result. I'm using Xgpro v11.10.
  1. **************************************************************
  2. APP Version : 11.10   Model : T56
  3.      Device : OKI16911(8b)  @DIP8
  4. **************************************************************
  5. Pins Detected Passed!
  6. Erase  ...Succeeded. Time : 0.015 S
  7. Programming FLASH ...Succeeded. Time : 31ms
  8. Verifing FLASH ...
  9. ERROR!   CODE Address:0x000000    Buf_Val:0xFD    IC_Val:0xFF
  10. Programming  ...Failed
复制代码
作者: admin    时间: 2021-7-22 09:12
回复 5# wLLm
I view the data sheet  of TS59C11 /OKI MSM16911/AT59C11 . they are all the same.
I tested no problem
图片附件: OKI59C11.png (2021-7-22 09:12, 27.92 KB) / 下载次数 31242
http://forums.xgecu.com/attachment.php?aid=807&k=4e5b0cbd9b9dea82ce16224f643ed01a&t=1793331255&sid=uDjWL2
作者: wLLm    时间: 2021-7-22 17:31
回复  wLLm
I t ...
admin 发表于 2021-7-22 09:12
Thanks for the reply, indeed, I should be able to program the chips with T56. What could be the issue that I cannot write the chips? The chips I have are new oldstock OKI 16911G and TS59C11.
update:
I was able to write an Atmel AT59C11. But the original 16911's that I have won't write the same goes for TS59C11. The OKI and TS are quite a bit older than the Atmel one. Eventough the chips are the same, could it be that there is some timing issue perhaps? Which chip did you test exactly?
If I read the datasheets correctly, Atmel's chip is from 1998, TS is from 1988. For the 16911 I could not find a date reference in the datasheets but I expect this could be late 1980s or early 1990s.
One difference that I could find is the max Clock Frequency. for AT59C11 that's 1MHz and for ST59C11 and MSM16911 that's 250KHz. There are also slight differences in the opcodes, it seems that AT59C11 is a bit more flexible than it's compatible counterparts.
作者: admin    时间: 2021-7-23 10:03
回复 7# wLLm
T56 Frequency  Clock is 250KHz. and opcodes is right.
Please wait, I will buy OKI MSM16911 to test.
作者: admin    时间: 2021-7-26 11:55
回复 7# wLLm
The reason has been found and we will be fixed in the next upgrade.
作者: wLLm    时间: 2021-7-26 22:29
回复  wLLm
admin 发表于 2021-7-26 11:55
I'm looking forward to the upgrade! Is it included in the 11.11 version? Just out of curiosity, what was the issue?
作者: wLLm    时间: 2021-8-7 04:08
回复  wLLm
Thanks a lot! it works I can finally program the 16911G! Great service and a great product :)
