标题: TL866 plus [打印本页]
作者: henry1234    时间: 2020-4-12 14:53     标题: TL866 plus
Can anybody just help me to write K9F2G08U0C flash program in any way. please help me thanks
作者: admin    时间: 2020-4-13 11:13
图片附件: T7.jpg (2020-4-13 11:13, 173.27 KB) / 下载次数 11765
http://forums.xgecu.com/attachment.php?aid=46&k=9bf39d3047ad13124c6570b73b06ae70&t=1793298043&sid=urUr61
作者: henry1234    时间: 2020-4-14 14:55
Read file ok, write file stop
作者: admin    时间: 2020-4-16 08:44
Please upload pictures about error information when writting.
作者: henry1234    时间: 2020-4-17 09:22
photo write error
图片附件: Capture.PNG (2020-4-17 09:20, 66.56 KB) / 下载次数 10552
http://forums.xgecu.com/attachment.php?aid=56&k=3c0d1ea7af23ac5e22fb88d098b41d6f&t=1793298043&sid=urUr61
作者: admin    时间: 2020-4-18 17:41
回复 5# henry1234
Please have a  test  for changing  R1 from 3K9 to 470ohm.
and Please upgrade to the newest software.
图片附件: Nand2.jpg (2020-4-18 17:40, 84.79 KB) / 下载次数 11298
http://forums.xgecu.com/attachment.php?aid=57&k=dc3208f0dbff511aa6536998a63cc38e&t=1793298043&sid=urUr61
作者: henry1234    时间: 2020-4-19 15:43
I replaced the R01 3.9k with the 470ohm con updating the new version, it still does not work.
in the configuration section I have followed theinstructions, whether in the configuration section I did wrong. can you help meconfigure this K9F2G08U0C nand.
Thank you my friend.
图片附件: Capture.PNG (2020-4-19 15:43, 41.38 KB) / 下载次数 10333
http://forums.xgecu.com/attachment.php?aid=58&k=9e2982d1cc77f43d79ffd3a4589a05af&t=1793298043&sid=urUr61
作者: admin    时间: 2020-4-19 18:43
upload new picture about wrong message.you may not program it again.  just verify it directly.
作者: henry1234    时间: 2020-4-20 16:00
programming stop.
图片附件: Capture.PNG (2020-4-20 15:59, 73.6 KB) / 下载次数 10488
http://forums.xgecu.com/attachment.php?aid=63&k=ad66a7ec1c1da248208ff6c66d2b3962&t=1793298043&sid=urUr61
图片附件: Capture.PNG (2020-4-20 16:00, 73.6 KB) / 下载次数 10530
http://forums.xgecu.com/attachment.php?aid=64&k=da27bc87ee216e6f17c2fda807f04465&t=1793298043&sid=urUr61
作者: admin    时间: 2020-4-20 17:23
回复 9# henry1234
Could you verifying again directly , after stopping. (Not Programming again). it will get more information .I had a test ,ervery thing is normal.(USE a 147MB file to test)
this chip has 2 bad blocks No.471 and No.675.
because  use hard copy and   datas can not be written into the bad block. so it is wrong at Block 471#
Maybe you used a bad adapter, can you re-solder and clean it,
图片附件: TC58_NAND_3.jpg (2020-4-20 17:36, 62.7 KB) / 下载次数 10989
http://forums.xgecu.com/attachment.php?aid=65&k=1d46f463fce21b69d8786bbaf4ae495c&t=1793298043&sid=urUr61
作者: henry1234    时间: 2020-4-22 16:38
I replaced 3k9 with 470ohm, soldering the chip on the circuit and still programming stop.
图片附件: Capture.PNG (2020-4-22 16:37, 59.07 KB) / 下载次数 10395
http://forums.xgecu.com/attachment.php?aid=72&k=823347ade38feaadc3fb8d0ef32803b1&t=1793298043&sid=urUr61
图片附件: Capture 2.PNG (2020-4-22 16:37, 138.92 KB) / 下载次数 10836
http://forums.xgecu.com/attachment.php?aid=73&k=74f66b77415f87100f3121ccad8b711a&t=1793298043&sid=urUr61
作者: admin    时间: 2020-4-27 12:24
回复 11# henry1234
Please refer to this post, whether it can solve the problem of NANDhttp://forums.xgecu.com/viewthread.php?tid=28&extra=page%3D1
