标题: M27C1000 / 27c301 support [打印本页]
作者: Rom1    时间: 2021-5-8 04:42     标题: M27C1000 / 27c301 support
Programmer doesn't support M27C1000 eprom. Here is the datasheet link: https://www.datasheets360.com/pdf/-2525214309807721890
They program the same way as 27c010/27c1001/MX27c1000 but some pin are not in the same place:
Image comes from here: https://forums.arcade-museum.com ... cb-5-0-98db.311726/
Thanks for your help,
Regards
作者: admin    时间: 2021-5-8 08:37
回复 1# Rom1
thanks. we will add  these chips in next version
作者: Rom1    时间: 2021-5-8 18:35
A big thank you :)
