标题: 27c322 bug ? [打印本页]
作者: Rom1    时间: 2021-5-8 04:38     标题: 27c322 bug ?
I have a T56 and some 27c322 are not programming correctly.
- The chips are fully erased, blank checked OK.
- Programming step goes well.
- Verify check tells me there is differences with binary image.
The same chip program OK on a Wellon VP280.
I also cross checked: programmed by VP280 are verified OK by T56; and programmed by T56 are both verified as ERROR on T56 and VP280.
I have another batch of 27c322 that is ok and program well on both.
Maybe a problem in settings or algorithm ?
Regards
作者: admin    时间: 2021-5-8 08:14
回复 1# Rom1
Please try to change Pulse Delay time  from 50us to 200us.
or change VDD write: 6.25V->5.5V testing
图片附件: 阿里旺旺图片20210508082534.jpg (2021-5-8 08:14, 21.67 KB) / 下载次数 21675
http://forums.xgecu.com/attachment.php?aid=504&k=6b85b491bb2fa9efb2b73975494ad98b&t=1793239298&sid=9F5U50
作者: Rom1    时间: 2021-5-8 18:34
Thanks for your help.
I'll already tried changing pulse to 100us with no success.
Yesterday I pushed VDD write to 6.5v and every chip is programming right with only this change.
I'll give a try to both 200us and VDD 5.5v and keep you informed.
作者: Rom1    时间: 2021-5-11 06:53
Changing pulse time didn't work.
Reducing VDD was a success. How can you explain that both reducing and increasing VDD helps ?
Thanks a lot !
作者: admin    时间: 2021-5-11 08:40
回复 4# Rom1
The production date of this 27C series chip is relatively early, and the original factory seems to have stopped production, which may be related to the internal charging circuit of the chip during programming.
