标题: Logic Test - Files structure (*.lst *.lgc) [打印本页]
作者: yovish    时间: 2021-3-10 06:09     标题: Logic Test - Files structure (*.lst *.lgc)
Can you describe the structure of the logicUser.lst file and *.lgc files?
作者: yovish    时间: 2021-3-10 22:42
What I have been able to analyze so far...
图片附件: Logic_lst.JPG (2021-3-10 22:42, 137.62 KB) / 下载次数 24450
http://forums.xgecu.com/attachment.php?aid=299&k=5a9bf1a9326ac6d16f468442114284b5&t=1793442480&sid=1miIiN
作者: admin    时间: 2021-3-11 11:06
回复 2# yovish
#define LOGIC_UFILE_FLAG  0xABABABEE
#define MAX_LOGIC_ITEM  512
typedef struct LOGIC_ITEM_FILE_HEADTag
UINT AllCRC32;// all Items CRC32
UINT uiFlag;    //
LOGIC_UFILE_FLAG
UINT AllItemCnt;
UINT Res;
UINT ItemStartPos[MAX_LOGIC_ITEM];  //start postion in the file
}LOGIC_FILE_HEAD;
typedef struct LOGIC_ITEM_Tag
UINT Vector_Cnt;
char IcName[32];
BYTE VccVoltage; //0-3
BYTE AllPins;
BYTE Res0;
BYTE Res1;
UINT uiRes;
}LOGIC_ITEM;
typedef struct LOGIC_VECTOR_Tag
char _byte[24];
}LOGIC_VECTOR;
作者: yovish    时间: 2021-3-11 23:05
1. From which areas of the file is CRC32 counted?
2. Is the space between LOGIC_FILE_HEAD and LOGIC_ITEM reserved for the future?
3. Can the space between LOGIC_FILE_HEAD and LOGIC_ITEM have random content?
4. How exactly is CRC32 calculated?
作者: admin    时间: 2021-3-12 13:29
回复 4# yovish
CRC32 is all LOGIC_ITEM+LOGIC_VECTOR .The initial value is 0
作者: yovish    时间: 2021-3-13 05:47
Something is wrong with this CRC32 ...
In the "4052.lgc" file shown, the selected area is LOGIC_ITEM+LOGIC_VECTOR. The counted CRC32 is at the bottom and is different from that in the file?!?
图片附件: 4052_CRC.jpg (2021-3-13 05:47, 528.11 KB) / 下载次数 30432
http://forums.xgecu.com/attachment.php?aid=305&k=7ee960c54438531e4265d6fdba87f517&t=1793442480&sid=1miIiN
附件: 4052.lgc (2021-3-13 05:49, 2.27 KB) / 下载次数 53854
http://forums.xgecu.com/attachment.php?aid=306&k=07a7d8ad9f790dc3003d7217a11e02ab&t=1793442480&sid=1miIiN
作者: yovish    时间: 2021-3-18 18:58
Please describe to me the CRC32 counting process in more detail. This will allow me to better use the potential of this programmer as a logic tester, because you do not want to add the additional functions I have proposed (import / export to text files, http://forums.xgecu.com/viewthread.php?tid=185&extra=page%3D1).
作者: firsthand    时间: 2024-1-8 09:04
I would also be interested in either more information about the format of the LST file, or a tool that allows you to IMPORT vectors.
