标题: TC58DVM92A5TA10 NAND Bug [打印本页]
作者: Test    时间: 2021-2-18 00:32     标题: TC58DVM92A5TA10 NAND Bug
Hi!
After one of the latest T56 programmer SW updates (I believe where NAND .hex/.bin is loaded into Block Buffer) it is unable to Program/Read/Verify Toshiba's TC58DVM92A5TA10 NAND memory IC. It constantly gives Verification Errors. Tried with several good NANDs.
Please see the Result here:
https://prnt.sc/zvhxcl
https://prnt.sc/zvi07v
作者: Test    时间: 2021-2-18 00:47
Update: it seems the bug only occures when 3.0V is selected. 1.8V and 3.3V works good.https://prnt.sc/zvjxm3
