标题: Reading problem emmc [打印本页]
作者: Test    时间: 2021-1-27 18:32     标题: Reading problem emmc
Is there a way to read this emmc or wait for it to be added in the program list?
KFG1GN6W2D
作者: admin    时间: 2021-1-28 09:07
回复 1# Test
this not a emmc ,this is a oneNAND Flash, do you have the data sheet?
we will add it later.
作者: Test    时间: 2021-1-28 17:14
Good...
I found these to be possibly helpful
If the information is not identical
You can request it from the company
KFG1G1612M-DEB5 Datasheet pdf - FLASH MEMORY(54MHz) - Samsung Electronic (datasheetcatalog.com)
or
KFG1GN6W2D [FBGA63] - Samsung | Elnec
