标题: can add ..H27UCG8T2FTR [打印本页]
作者: Test    时间: 2021-1-20 02:08     标题: can add ..H27UCG8T2FTR
Please...
add support for NAND ...H27UCG8T2FTR...
I did not find it in the list
作者: admin    时间: 2021-1-20 12:11
回复 1# Test
do you have the data sheet?
you have a test with custom Parameters:
图片附件: NAND.png (2021-1-20 12:10, 14.7 KB) / 下载次数 15465
http://forums.xgecu.com/attachment.php?aid=242&k=7d7a91e8a0524ba210c8ad37304ad0f3&t=1793839451&sid=pdjR99
作者: Test    时间: 2021-1-29 14:57
here is the datasheet For H27UCG8T2FTR
H27UCG8T2BTR-BC pdf, H27UCG8T2BTR-BC description, H27UCG8T2BTR-BC datasheets, H27UCG8T2BTR-BC view ::: ALLDATASHEET :::
H27UCG8T2ETR Datasheet - 64Gb MLC NAND Flash Memory - DataSheetCafe.com
Good luck   :)
