标题: AT89LP4052 [打印本页]
作者: sreaves    时间: 2025-2-16 02:26     标题: AT89LP4052
Would you please add support for the Atmel/Microchip AT89LP4052?
I have been asking for this for probably 2+ Years now.
Here is the link for all of the documents for this part:
https://www.microchip.com/en-us/product/AT89LP4052
These devices can use either ISP serial programming or parallel programming as described on page 57 and 59 of the complete datasheet. The parallel programming mode might be easier to implement for the T-56 or the TL-866+ as it does not require a clock. AT89LP4052_Complete Datasheet_doc3547.pdf (1.81 MB) AT89LP4052_ISP_Programming_doc3593.pdf (593.65 KB)
I have attached the complete datasheet as well as the ISP programming data sheet.
Sam
W3OHM
附件: [Full Datasheet] AT89LP4052_Complete Datasheet_doc3547.pdf (2025-2-16 02:24, 1.81 MB) / 下载次数 9278
http://forums.xgecu.com/attachment.php?aid=2265&k=20840973ebad4546b3d7d6fef5c25970&t=1793280856&sid=FoE8i9
附件: [ISP Programming] AT89LP4052_ISP_Programming_doc3593.pdf (2025-2-16 02:25, 593.65 KB) / 下载次数 7221
http://forums.xgecu.com/attachment.php?aid=2266&k=c8fb6f92b9dc220bee484f5a1808cb98&t=1793280856&sid=FoE8i9
