标题: TMS2716 [打印本页]
作者: sreaves    时间: 2025-2-16 02:08     标题: TMS2716
The device list for the T56 has the TMS2716 EPROM listed but it clearly can not program this device. The TMS2716 is unique as it requires +5, -5, +12V for normal operation and also requires that Vcc be raised to +12V for programming. Additionally the device also needs +25V for Vpp.
So some sort of adapter will be needed that can generate these voltages.
This is unlike other TMS27XX parts like the TMS2516 which only need +5V and the appropriate Vpp voltage.
I attached a datasheet for the TMS2716 but it can also be found here:
https://www.alldatasheet.com/datasheet-pdf/pdf/125762/TI/TMS2716.html
If anyone happens to have a design for an adapter I would gladly do a PCB layout for such a device and put it up on JLCPCB so that others can
benefit. I would do the design myself but I have way to many projects at the moment.
Sam
W3OHM
附件: TMS2716.PDF (2025-2-16 02:07, 406.08 KB) / 下载次数 6664
http://forums.xgecu.com/attachment.php?aid=2264&k=3e99a183ad08bc1b0c543f968f74c31b&t=1793406859&sid=89P6Jz
