标题:
XGecu Pro 不能正常读写M24256E2Prom芯片
[打印本页]
作者:
diodes_1
时间:
2025-1-8 22:06
标题:
如题,XGecu Pro在读取M24256时,总是提示过流或者芯片短路,芯片在希尔特500P上读写正常,没有问题。请咱们的技术人员把这个BUG解决了吧!
作者:
Albano.Matos
时间:
2025-1-10 14:34
如题,XGecu Pro在读取M24256时,总是提示过流或者芯片短路,芯片在希尔特500P上读写正常,没有问题。请咱们 ...
diodes_1 发表于 2025-1-8 22:06
Hello, You have the possibility to adjust manually the 'VCC Current Imax: ' in small increment steps.
If you have time, as you know the chip is good, change a bit the parameter, and post here the results,
please.
Rgds
Powered by Discuz! 7.2
