标题: Mx30uf4g16ab contact error when reading the entire FF dump the chip is not empty [打印本页]
作者: Dmitry    时间: 2024-12-19 18:15     标题: Mx30uf4g16ab contact error when reading the entire FF dump the chip is not empty
T56 Contact error when reading the entire FF dump the chip is not empty. Another programmer reads the chip
作者: Dmitry    时间: 2024-12-19 18:36
what to do? All dump FF
图片附件: IMG20241219132319.jpg (2024-12-19 18:28, 464.92 KB) / 下载次数 3348
http://forums.xgecu.com/attachment.php?aid=2259&k=819b83f1cf999732f92448a16ba8d8c9&t=1793350618&sid=5J5tar
图片附件: IMG20241219132710.jpg (2024-12-19 18:28, 529.59 KB) / 下载次数 3303
http://forums.xgecu.com/attachment.php?aid=2260&k=cbc70a300494ea9e6ad99ef7c3cc1529&t=1793350618&sid=5J5tar
作者: Albano.Matos    时间: 2024-12-19 22:12
[quote]what to do? All dump FF
Dmitry 发表于 2024-12-19 18:36
Dear Dmitry,
                   Try latest known software HTTPS://www.hklrf.com/Downloadfile_59.html ,
with some corrected ICs. Why? You got one error with one address lines, you should got
multiple errors....
Anyway, if not help, please post your adapter, clean it ( just in case), if adapter socket is removal
capable, clean everything. No Good? Wait as T76 is almost out and a new software will appear.The IC used maybe have bad sector...
Hope it helps
作者: Dmitry    时间: 2024-12-22 17:59
Ответить 3# Альбано.Матос
Albano hello, I use the latest version of the software, adapter, rang, all contacts are working. This contact on the chip does not ring anywhere, in my opinion this is the ground contact, I forcibly made a jumper to another ground contact, the error in determining the contacts disappeared, but nothing changed, the dump also remains empty (FF). Why there is only one error in the log I do not know, most likely the code for working with this chip is not finished. The chip is working, fully works in the device and does not fail. I do not understand why the programmer support does not respond to problems. I have another programmer, not xgcue, it reads this chip, but with errors, tech support advised me to read the documentation and play with delays.
作者: Dmitry    时间: 2025-1-2 05:39
Albano I tested, unfortunately came across 2 faulty chips, which gave errors in different places. Were replaced with new ones, but the contact error on them remained, just ignored, or make a jumper on gnd according to the connection compression of the adapter contact (only for this series chip)
作者: Albano.Matos    时间: 2025-1-2 14:12
Ответить  Альбано.Матос
Albano I tested, unfortunately came across 2 faulty  ...
Dmitry 发表于 2025-1-2 05:39
   Hello,            Thank you for share your findings and experience. Please post the pic of your adapter,
as 3 already exist for T56. Maybe Admin correct it , hopefully.  :)
作者: Dmitry    时间: 2025-1-13 23:34
Ответить 6# Альбано.Матос
I ordered a regular adapter for the t56 model using the number in the app. About 2 months ago, so I think it hasn't had time to go bad)) This is some kind of problem with these chips
图片附件: IMG20250113182615.jpg (2025-1-13 23:29, 77.02 KB) / 下载次数 2500
http://forums.xgecu.com/attachment.php?aid=2262&k=921bd4e9d4039aa154e14448b948e438&t=1793350618&sid=5J5tar
图片附件: IMG20250113182648.jpg (2025-1-13 23:29, 133.17 KB) / 下载次数 2706
http://forums.xgecu.com/attachment.php?aid=2263&k=5ed93e859678803b24a7054b68ca6a1e&t=1793350618&sid=5J5tar
作者: Albano.Matos    时间: 2025-1-14 15:33
I ordered a regular adapter for the t56 model using th ...
Dmitry 发表于 2025-1-13 23:34
Hello, or maybe the software needs adjustment. With all the data now here, software and socket
seems one of the originals from Xgecu, hopefully they fix it, or give a tip :)
