标题: Sandisk SD5C25A-8G/16G eMMC BGA169 Support [打印本页]
作者: metacreo    时间: 2020-12-29 17:54     标题: Sandisk SD5C25A-8G/16G eMMC BGA169 Support
Can you add Sandisk SD5C25A-8G SD5C25A-16G eMMC BGA169 Support please.
I tried auto init SD5C25A-8G No success.This chips most used in smartphones. Honor, Mate, etc... Also often used as common flash memory.
作者: admin    时间: 2020-12-30 11:17
There should be same as  others. I'll get samples to test
作者: admin    时间: 2021-1-3 13:01
I got 2 samples.SDC25A-8G
Result tested:   no problem
check your adapter's C10 on top of PCB,  Some sellers have wrongly soldered a capacitor C10.
The correct capacitance is 15p. They used a 0.1uf.
图片附件: SDC25A.png (2021-1-3 13:04, 54.99 KB) / 下载次数 16360
http://forums.xgecu.com/attachment.php?aid=238&k=ef26a28e351455c88b932b291cb46390&t=1793259071&sid=1XzYal
作者: metacreo    时间: 2021-1-5 02:00
Thank You. You 100% right. I replaced capacity on my adapter to 15pf and now I can read/write succesfully. Thanks.
作者: Test    时间: 2021-1-7 02:29
good solution
May I know what adapter is
