Hello, please help. I'm trying to read AMD L256ML123R1 BGA64. For this I use the BGA64A-1.0 adapter. The program shows that all contacts are bad. When I used the old version of the program, everything worked. If I remember it right . Please fix this problem. Thank you.作者: T56prog 时间: 2024-3-3 11:00
I'm sorry, I found the problem was a bad BGA adapter
