Hello guys, I bought a T56 programmer yesterday and tried five emmc chips and noticed that the maxim ...
Elarapy 发表于 2024-1-9 17:01
These emmc chipsets were tested on Easy jtag Plus and were programmed at a speed of 24 MB per second ...
Elarapy 发表于 2024-1-9 18:59
Thank you my friend for following
It is not possible to use an old version of the program because i ...
Elarapy 发表于 2024-1-13 08:11
Obviously, the speed limit is set by software. The weak point of the T56, which limits its speed - i ...
Test 发表于 2024-1-19 09:12
The speed of the T56 is limited by the XGecu software. The USB-COM bridge is located in T56. Impleme ...
Test 发表于 2024-1-19 17:55
The data for T56 in this table are valid only at the beginning of the appearance of T56. At the time ...
Test 发表于 2024-1-22 00:32
欢迎光临 XGecu Programmer Forums (http://forums.xgecu.com/) | Powered by Discuz! 7.2 |
