标题: PIC12F629 is not working with T48, but was working with TL866II [打印本页]
作者: tzok    时间: 2023-12-24 19:58     标题: PIC12F629 is not working with T48, but was working with TL866II
I'm writing to report that support for PIC12F629 is broken for T48, while using same SW version it is supported by TL866II-Plus.
作者: paul    时间: 2024-1-1 13:15
I am also having problem with PIC 12F629.  I am using latest XGpro software v12.63 .  I have purchased two "new" IC's and the T48 cannot program either one.  When I attempt to program the IC, the XGPro software clears all flags and memory by putting 0's (zero) in the contents.  Program Memory = all 0's.  Data Memory = all 0's.  Config Word = all 0's.  When I try to perform ERASE function, it does not work.  Everything remains 0's.  Note that a blank chip should have all F's instead.  I noticed you have 3 other forum discussions on this same topic.  Therefore, I will post this message 3 times. I can't tell you how much time and effort I and other have wasted on this.  Will probably have to buy a Microchip PicKit instead, because I cannot wait for you to release your next version of XGPro.  Thanks.
