标题: 2716 does not work [打印本页]
作者: JPT    时间: 2023-11-21 01:39     标题: 2716 does not work
I've got several Apple II+ ROMs that should be READ-compatible with 2716. But the TL866II-Plus cannot read any. I always get FF.
Different sources tell they are 9416 or 2316. Does not really matter as they are OTP. I just want to read them to check if they are OK.
Also I got a UV-erasable NEC D2716D which cannot be read. Did not try write.
any idea why this does not work?
thanks
JPT
作者: Albano.Matos    时间: 2023-11-21 12:38
I've got several Apple II+ ROMs that should be READ-compatible with 2716. But the TL866II-Pl ...
JPT 发表于 2023-11-21 01:39
    As a user,
                  Can you, please, upload images that show your problems?Rgds
