APP Version: 12.63 Model: T48
Device: H26M52103FMR_1Bit @BGA153
Adapter: ADP_EMMC_BGA153...OK
Pins Detected Passed!
Init EMMC... OK! (OCR register: C0FF8080)
Reading ECSD: Succeeded
RPMB Protected by Authentication Key ,Operation OK
RPMB Writer Counter: 39566
C:Calcu.available disk capacity: 787 GB
Reading BOOT1: Succeeded. Time: 1.141 S -- Partition Size: 4096 KB
Reading BOOT2: Succeeded. Time: 1.156 S -- Partition Size: 4096 KB
Reading RPMB :Succeeded. Time : 2.953 S -- Partition Size :4096 KB
Reading User Area : Succeeded. Time : 4709.672 S -- Partition Size :15392768 KB
Reading Succeeded 32 bits CheckSum : 0x F3982A0F
All saved to the folder: C:\Xgpro\UserData\Emmc_data(slow1b)
Verify Restart EMMC ....
Init EMMC... OK! ( OCR register: C0FF8080 )
Verifying CSD Succeeded
Verifying ECSD Succeeded
Verifying BOOT1 : Succeeded. Time : 1.156 S -- Partition Size :4096 KB Processing Size from the File : 4096 KB )
Verifying BOOT2 : Succeeded. Time : 1.156 S -- Partition Size :4096 KB Processing Size from the File : 4096 KB )
Verifying RPMB : Succeeded. Time : 2938 ms -- Partition Size :4096 KB
Analysis file is complete, Space usage: 62.98% time: 61S
Verifying User Area ...
Verify Error at Address 0x00_06210C04: Source data: 0x01 -- Target data: 0x81
Verify Error at Address 0x00_06210C0B: Source data: 0x60 -- Target data: 0x68
Verify Error at Address 0x00_06210C10: Source data: 0x01 -- Target data: 0x03
Verify Error at Address 0x00_06210C11: Source data: 0x68 -- Target data: 0x6C
Verify Error at Address 0x00_06210C19: Source data: 0x7D -- Target data: 0x3D
Verify Error at Address 0x00_06210C21: Source data: 0x02 -- Target data: 0x00 Verify Error at Address
0x00_06210C2A: Source data: 0x1E -- Target data: 0x3E
Verify Error at Address 0x00_06210C2D: Source data: 0xBC -- Target data: 0xB4
Verify Error at Address 0x00_06210C34: Source data: 0x08 -- Target data: 0x09
Verify Error at Address 0x00_06210C38: Source data: 0x01 -- Target data: 0x11
Verify Error at Address 0x00_06210C4F: Source data: 0x45 -- Target data: 0x55
Verify Error at Address 0x00_06210C5D: Source data: 0x02 -- Target data: 0x00
Verify Error at Address 0x00_06210C62: Source data: 0x48 -- Target data: 0xC0
Verify Error at Address 0x00_06210C69: Source data: 0x2D -- Target data: 0x0D Verify Error at Address
0x00_06210C78: Source data: 0x9D -- Target data: 0xDD
Verify Error at Address 0x00_06210C7F: Source data: 0xCB -- Target data: 0xCF
Verify Error at Address 0x00_06210C80: Source data: 0x49 -- Target data: 0x48
Verify Error at Address 0x00_06210C81: Source data: 0x95 -- Target data: 0x85
Verify Error at Address 0x00_06210C82: Source data: 0x02 -- Target data: 0x83
Verify Error at Address 0x00_06210C85: Source data: 0x03 -- Target data: 0x83
Verify Error at Address 0x00_06210C89: Source data: 0x00 -- Target data: 0x41
Verify Error at Address 0x00_06210C8B: Source data: 0x5D -- Target data: 0x55
Verify Error at Address 0x00_06210C9B: Source data: 0x79 -- Target data: 0x7D
Verify Error at Address 0x00_06210C9F: Source data: 0x80 -- Target data: 0x84
Verify Error at Address 0x00_06210CA3: Source data: 0xED -- Target data: 0xEC
Verify Error at Address 0x00_06210CA6: Source data: 0x20 -- Target data: 0x24
Verify Error at Address 0x00_06210CA7: Source data: 0x1A -- Target data: 0x5A
Verify Error at Address 0x00_06210CA9: Source data: 0x00 -- Target data: 0x20
Verify Error at Address 0x00_06210CB9: Source data: 0xE7 -- Target data: 0xA7
Verify Error at Address 0x00_06210CBF: Source data: 0x00 -- Target data: 0x80 Verify
Error at Address 0x00_06210CC3: Source data: 0xFC -- Target data: 0xE8
Verify Error at Address 0x00_06210CC7: Source data: 0xCC -- Target data: 0xDC
The number of incorrect data is greater than 32 .
Verifying User AreaFailed Error Counter: 17642
| 欢迎光临 XGecu Programmer Forums (http://forums.xgecu.com/) | Powered by Discuz! 7.2 |
