标题: Eprom 27513 i 27011 [打印本页]
作者: szkieletor11111    时间: 2023-7-11 18:45     标题: Eprom 27513 i 27011
when will you finally add Eprom 27513 and 27011 to T48?
in the T56 it's been added for a long time to hell.
作者: Test    时间: 2023-9-9 04:20
I would also want 27513 support.Or is it possible to add it to the T48 Programmer as a custom chip?
If so, how can it be done?
I added the datasheet for INTELs 27513 Bank-Selecting ROM in case someone decides to help.
作者: Test    时间: 2023-9-9 04:21
Here is the attachment
D27513_Datasheet.pdf (787.51 KB)
附件: D27513_Datasheet.pdf (2023-9-9 04:20, 787.51 KB) / 下载次数 24423
http://forums.xgecu.com/attachment.php?aid=1987&k=e20528fd68db52ad7f99448e68100554&t=1793420699&sid=FsCFZO
