标题:
Programming Failed
[打印本页]
作者:
RubbVandal
时间:
2023-6-8 01:37
标题:
Programming Failed
hi, I need help writing in AM29F010B,
Blank Check, Check ID and Pin Detect: success.
I tried disable verify after, erase before and skip blank but got the same error.
Log output:
APP Version : 12.57 Model : T48
Device : AM29F010B @PLCC32
Pins Detected Passed!
ID: 0x 01 20 ......OK!
Erase ...Succeeded. Time : 0.406 S
Programming FLASH ...
ERROR! Address:0x000030 Buffer Data:0x08 Verify:0xFF
Programming ...Failed
I am not able to write anything on this memory, i got the same error no matter what address I am trying to write
图片附件:
(2023-6-8 01:37, 693.18 KB) / 下载次数 12659
http://forums.xgecu.com/attachment.php?aid=1866&k=09d5405404b900f88b61c656a1d3771f&t=1793497912&sid=Hk89fC
作者:
RubbVandal
时间:
2023-6-9 02:24
Solved. Turn out that the zip adapter had a short in two data lines.
This was the same issue that causes the problem covered in this other post:
http://forums.xgecu.com/viewthread.php?tid=1107&extra=page%3D1
Powered by Discuz! 7.2
