I have a problem with the TL866II plus programmer.When I try to read the XR2804 chip is reported "Bad pin found" relatedto pin 22 and 19 . I tried different chips but the problem remains.I have the same problem using the T48 programmer. Do you have a solutions?
Thank you
Giangiacomo
I have a problem with the TL866II plus programmer.When I try to read the XR2804 chip is repor ...
Elektron 发表于 2023-5-30 00:28
| 欢迎光临 XGecu Programmer Forums (http://forums.xgecu.com/) | Powered by Discuz! 7.2 |
