hello every onecan you add the ATMEGA16, 32, 644 etc... TQFP packages to the list
thank you作者: Abdulkerim 时间: 2020-10-12 04:06
we need to parallel conection作者: admin 时间: 2020-10-14 16:34
回复 2#Abdulkerim
TL866II only 40 PINs IO. canot support it TQFP44 directly.No versatility.
This is a very simple DIY. There is no difference between what you do and what we do.
see the atmel datasheet. DIY adapter form TQFP44 to DIP40.作者: Abdulkerim 时间: 2020-10-17 02:37
回复 3#admin
i know that
but i need to connect it as parallel
how can we connect the atmega16 as parallel
thank you作者: Abdulkerim 时间: 2020-10-17 02:43
