标题: Problem with VCCQ EMMC via ISP [打印本页]
作者: STALKER_71    时间: 2020-10-10 04:03     标题: Problem with VCCQ EMMC via ISP
Hi, the XGecu T56 has a problem with the VCCQ power supply when the programming through the ISP connector and the vccq power is taken from the zif panel pins.  If you put vcc3.3v \ vccq1.8v at the zif output of the panel vccq = 0.9-1.0v.  I have to submit vccq separately external power.  When I expose vcc3.3v \ vccq3.3v Everything is fine and vccq is 3.3v.  Why is voltage so low at 1.8?
作者: admin    时间: 2020-10-10 11:18
回复 1# STALKER_71
ISP no 1.8V VCCQ.
   http://forums.xgecu.com/viewthread.php?tid=71&;extra=page%3D1
作者: STALKER_71    时间: 2020-10-10 17:22
Isp no vccq but zif panel have vccq and it low 0.9-1v.
作者: STALKER_71    时间: 2020-10-11 04:11
If i take VCCQ power from this pins voltage 0.9v
图片附件: VCCQ.jpg (2020-10-11 04:09, 123.28 KB) / 下载次数 15637
http://forums.xgecu.com/attachment.php?aid=185&k=42e55b3d21e25b57a7418fc4c3a61e86&t=1793406491&sid=Qq867Q
作者: admin    时间: 2020-10-11 10:02
回复 4# STALKER_71
Since there is only one VCC voltage inside the programming hardware, when VCCQ=VCC, VCCQ exists, but when VCCQ=1.8V and VCC=3.3V, VCCQ is high impedance. Generally when using ISP, use external the board's power supply instead of the optional power of the programmer.
作者: STALKER_71    时间: 2020-10-11 16:26
That's what I do. Indicate it in the description. For a long time I figured out why there was no connection with emmc until I measured the power.
