T56 some feedback
T56 is positioning to have 'for developers' status. We need to force this and add the possibility to introduce a scripting language (С like nature) to do some 'very original' (DIY) operations for testing circuit and add custom chip quick support. To do so, the T56 programmer need to:
1. Output to the ZIF socket pins desured signals: CLK, pull-up, pull-down, VCC, GND, data bus and so on. It very similar as to logic testing. We need a make a signal sequences using this, for example, for read/write operations.
2. Read/Write internal IC data array, set/reset user programmable registers, bits to test custom DIY circuits.
3. Thanks to T56 powerful hardware this operations must be protected from any shorts and other broken risk to destroy the programmer.
Generally, it useful to add 'very original' (national) chips which is not needed for all customers.
I also looking to add the following modern Atmel AVR chips:
1. ATtiny10,ATtiny20,ATtiny40,ATtiny48-88.
2. ATtiny87-167
3. ATtiny102-104
4. ATtiny202-402,ATtiny212-412,ATtiny214-414-814,ATtiny441-841,ATtiny804-1604,ATtiny1614-1616-1617
5. ATtiny1634
6. PIC14000
7. W78E516DDG (Nuvoton)
