Please ADD & FIX For T56
To correct! Instead of 1.8V, the voltage is 1.5V
Add the ability to edit firmware (dump files or directly)
- open sections
- Edit partitions (for Android and other Linux systems)
- Definition of protective zones (calibrations, EFS, NVM, etc.) and read/Save file
- Finding informational data about the firmware (dump)
- Ability to upload(flash) factory firmware
- Erase user data (Factory Reset & Erase DATA)
only at 3.3V power ,VCCQ is valid.
Maybe you need some modification of the box? Here on the forum, most of the engineers will be able to fix it!
+ Ready to be a tester!
Add the ability to edit firmware (dump files or di ...
Oleg_Skalskiy 发表于 2022-10-10 17:36
Hand mode VCCQ 1,5V 🤔
Test 发表于 17-10-2022 04:19
    I installed AMS1117 1.8V on the adapter
But the partition manager is missing
回复 6# Oleg_Skalskiy
AMS1117-1.8V  is Is inappropriate.
need a LDO as XC6206 1.8V
回复  Oleg_Skalskiy
admin 发表于 18-10-2022 08:43
    Thanks
Thanks
Oleg_Skalskiy 发表于 18-10-2022 21:30
may be into the box to make a modification?
