AM27C010, AM29F010B, SST39SF010A not programing correctly
I have the TL866II plus and the T48, 2 PLCC32 to DIP32 adapters, I can't program any of my brand new devices AM27C010,  AM29F010B or SST39SF010A, the programmers sometimes write part of the devices but most commonly error is at address 800, I already damaged many 27c010 because they are one time programmable, I tried 4 different computers, windows xp, 10 or 11, 32 or 64 bits, why I'm having issues if they are in the supported list? I bought the devices from the distributors, no clones. Please help.
Best regards, vijo
Ps: they read fine and the ID also is fine
I have the TL866II plus and the T48, 2 PLCC32 to DIP32 adapters, I can't program any of my b ...
vijovijo Posted on 2022-8-18 09:32
Also I noticed the 27c010 on the software  have 2 versions, DIP32 and PLCC32, the 27c010 only comes in DIP28 or PLCC32, so I suspect there is something wrong with the pin configuration. Or maybe I need a PLCC32 to DIP28 adapter instead the PLCC32 to DIP32?
Also I noticed the 27c010 on the software  have 2 versions, DIP32 and PLCC32, the 27c010 only come ...
vijovijo 发表于 2022-8-18 10:08
   As a user:       The 'trick' to use the PLCC32 --> DIP28, is that you need to select the DIP version in the software ( if you already have one of those adapters available), seems not correct with this IC, as Admin warn, as is DIP Version is 32pin, not28pin :-(
Maybe faulty IC batch , or faulty adapter ( try pin to pin test with meter )
Recommend you buy ZIF adapter like this one Adp-062 Plcc32-dip32 Zif Adapter/ Adaptor/ Ic Socket Yamaichi For Tl866a Tl866cs Tl866ii Plus Or Other Universal Programmers - Calculators - AliExpress
Hope it helps
回复 2# vijovijo
1. 27C010 is not DIP28!  only 32PIns IC
address 800   error ------> A11 pin is bad  of your adapter
2. It should  your PLCC32 adapter is bad.
   PLCC32  shuld to DIP32  , not to DIP28
3, I tested TL866II and T48, all is normal!
T48
TL866II
Reply to vijovijo
1. 27C010 is not DIP28! only 32PINs IC
address 800 error ------> A11 pin is ...
admin Posted at 2022-8-18 11:48
Thanks for your reply, I'll check again and inform back to you.
About the 27c010 DIP28, I got that from the original AMD datasheet, but it's ok, I have the PLCC32 version.
am27c010-150jc-26786332.pdf (96.85 KB)
Thank you and best regards,
Vijo
As a user:       The 'trick' to use the PLCC32 --> DIP28, is that you need to select the DI ...
Albano.Matos 发表于 2022-8-18 11:38
Could be a bad pin, but is not supposed to let you know a pin is bad? I thought that was part of the features, I have pin check selected. Anyway I ordered a new adapter, arrives Saturday. Thanks.
回复  vijovijo
admin 发表于 2022-8-18 11:48
Problem solved with AM29F010B, problem was the adapter, it was shorting some pins from the PLCC32 socket to the DIP32 pins, too near.
Thank you very much, I finally upgraded the software in my instrument.
Best regards, Vijo
Problem solved with AM29F010B, problem was the adapter, it was shorting some pins from the PLCC32  ...
vijovijo 发表于 2022-8-18 14:08
   As A User: Happy for you :).Some shops in internet do not test adapters, or do not test adapters correctly, even if selling legitimate
programmers. They seem like the originals....that's why i now bought only from Xgecu store if possible,
it's a bit more expensive but, many times, offer a better brand socket. With PLCCxx socket's used frequently,
only use ZIF made adapters like the one I've posted here, and much better to handle medium/large quantity
work.
Also tested SST39SF010A, working good, PLCC32 to DIP32 adapter fixed.
Thanks for the fast responce.
As A User: Happy for you .Some shops in internet do not test adapters, or do not test ada ...
Albano.Matos 发表于 2022-8-18 15:38
Thanks.
Here is the adapter I purchased and I don't recommend:
The PLCC socket is too near the DIP pins and shorted. Junk.
Thanks to all for the help.
