建议在保存文件的时候增加新建文件夹功能
每次保存文件都要再去我的电脑里添加文件夹,建议在程序里选择文件夹页面添加新建文件夹按钮
every time you save a file, you have to go to my computer to add a folder, it is recommended to select the folder page in the program to add a new folder button
wild boar posted on 2022-4-26 08:54
   Hello, As an User:                             As the button isn't there, i do it during the save process, but without leaving the 'save' to add folder in explorer:
File-->Save-->Browse-->in the 'save as' screen, right click mouse in the area where you want to add new folder, or navigate through till the place <-->new-->folder--> enter Folder name -->Enter the new folder created-->Verify the name of file ( just in case you click elsewhere in the process ), and press save.
The process is almost the same as you seem to do, but without separately entering 'my computer', and maybe loose focus  in the save process.   Maybe you like the words, or not, just trying to help till you get what you need, hopefully :)
这只能暴露了你对电脑的基础操作都不熟悉
q519948746 发表于 2022-4-26 20:52
我的并没有这个选项
EMMC功能里 并没有
回复 5# 野猪
EMMC里面直接在文件夹编辑框里面输入新的文件夹名字就行了
能随机生成 一个文件名就好了 这样避免 覆盖
