Great help for TV Repair decisions
Dear Admin,                   The programmers T56 and TL866II are great. Reading other user posts, found , what  maybe a solution
to decision replacing an IC, because is working ok, but corruption of data often reoccurs. Remove
reprogram and resolder the IC was a task that can be avoided if the IC is near wear out . A new one is needed...
Reading other post...
<1> -- Production Info.and Device life time--
      MID          : 45
      PNM          : DA4032
      Product Date : 3-2019
      Version      : MMC V5.1
      Device life time Type A : Exceeded its maximum estimated device life time
      Device life time Type B : 0%-10% device life time used
      Device life time (PRE_EOL_INFO) : Urgent
Question:
Is there a function that can help us, don't know if erase  command also erase statistics or not and
be done in order, to tell if the IC is near wear out?
One common IC that makes this problem is MX30LF1G08AA
Can you help?
Best Rgds
回复 1# Albano.Matos
Read the T56 programmer user guide  about EMMC.
test programming into a new IC with one_key_ghost function
