Problem with programming am29f800bb
Hello. I have read correctly am29f800bb but when i make changes and want to program it into chip i'm getting always error on 1,56%. That chip is from mercedes ecu. Here is pic of error and 2 bins (original and modifed).
Pic:
Bins:
https://www3.zippyshare.com/v/tKdev2Qf/file.html
What i'm doing wrong?
Maybe you need erase it before programming.
When i mark erase i got this same error and chip didn't erase at all but it should.
回复 3# riderss
I tested with AM29F800BT , all is normal.(BT and BB only boot is diffrent。use the same algorithm )
It can be confirmed that the software is correct.
clear pins contacts carefully!First  Read ID is Normal ,if not . bad pins or adapter.
回复  riderss
I tested with AM29F800BT , all is normal.(BT and BB only boot is diffrent。use the ...
admin 发表于 2021-6-26 10:11
My chip is AM29F800BB-55SE but i must uncheck "Check ID" to read chip but when i uncheck it its reads ok but i can't flash it back with changes. Got error on programming and i cant erase. Xgpro says erase is completed but chip isn't erased when i read it again.
  1. **************************************************************
  2. APP Version : 11.00   Model : TL866II Plus
  3.      Device : AM29F800BB  @SOP44
  4. **************************************************************
  5. Pins Detected Passed!
  6. Check ID Error!
  7. Checked ID is:0x02FA 35C4
  8. Wish to continue programming , please cancel [Check device ID] option!
复制代码
I have tested BT too and chip flashed ok but still have problem with flashing BB.
