Can not program tms2732A
Programming fails for TMS2732A.
Programmer disconnects and reconnects...
When I try external 5V, programmer disconnects and both POW and RUN lights on solid.
Here is log from when trying to program TMS2732A...
No Programmer Found.
1 Programmer Connected.
  Device 1: XGecu T56 Ver: 00.01.39
       USB POWER VOLTAGE: 05.10V
       USB SPEED MODE: HS 480MHZ
回复 1# chris.yeager
Insufficient USB power supply:
1.  plug it directly into the USB port of the computer motherboard.
2.  Use the original USB cable.
3.  Or use an external power supply
