Download Newest XGecu T76/T56/T48/TL866II software(下载最新软件)
软件下载,已经移动到新的网站页面:
Software download, has been moved to a new website page:
V13.09 for T76- Software and IC support List are here xgecu and or Xgpro_T76_V1309.rar - Blue Report...
1. Increased chip support to 39,659, adding 650 chips.
2. Completed support for SDNAND and TF/SD 1.0/2.0/3.0 cards, with read/write speeds up to 20+ MB/s. The SDNAND chip uses the WSON8 high-speed socket, and the TF/SD card uses the T76 dedicated SD card adapter.
3. Fixed several bugs and optimized multiple parts of the software for improved stability.
V13.06 for TL866II, T48, and T56- Lists  and software are here xgecu.
1. SD card and SD NAND algorithm optimization, greatly enhancing SD compatibility.
2. Increased logic testing for the 74 series.
3. Fixed some known defects.
4. Added support for some chips.
Supported Chips:
TL866II-.19353 from 19336 from 19326 from 19272 from 19023 from 18991
T48-----.36029 from 35993 from 35969 from 35779 from 35267 from 35138
T56-----.38850 from 38811 from 38783 from 38537 from 38062 from 37906
T76-----.39659 from 39009 from 38649 from 38540 from 38319 from 36111 from 35186
12.93
Good News, new T76 only software version is out. Now support 38540 ICs, list  and software is here xgecu
12.95
6. Fixed some known BUGs
Hello ,
T48--- ...
12.93
Hopefully, get it done.
lists, you can downl ...
Hello ,
Latest translated changes:
T76: 12.91.
12.91
12.89
3. Fixed known BUGs
12.85
3. Known BUGs have been fixed
T48-56-TL866II-12.90
12.90-12.88
1. Chip support quantity:
T56: 38537
TL866II: 19272
T48: 35779
12.78
T56 programmer:
Support: 37906 (+150)
T48 programmer:
Support: 35138 (+142)
TL866II programmer:
Support: 18991 (+75)
3. Fix known defects
FM28V020, 8582 fix
ATMEGA8A EEPROM Erase fix
12.67
T56 programmer:
Support: 37756 (+105)
T48 programmer:
Support: 34996 (+86)
TL866II programmer:
Support: 18916 (+26)
2. Newly added:
ZB25Qxxx
XM25RU128C
D27C011
and other chips
3. Fixed known defects
TMS27C240 fixed
AK6440AM AF fixed
Fixed other known bugs
12.66
Version: V12.66 2024.2.5
T56 programmer:
Support: 37651 (+158)
T48 programmer:
Support: 34910 (+120)
TL866II programmer:
Support: 18890 (+65)
and other chips
Thank you for the info.
I've noticed that communication here has become very scarce.
We're not asking for much, but the minimum should be there.
I've been involved since the first model, and there's a lot of potential in the project.
I would be very sorry if it were to fail now due to a lack of communication.
Let's hope things get better.
Test 发表于 2025-4-18 09:11
TL866II-.19023 from 18991
T48-----.35267 from 35138
T56-----.38062 from 37906
T76-----.36111 from 35186
liuyunx 发表于 2025-2-11 21:01
Hi, Please add Xicor X24645
tytka 发表于 2023-10-5 16:17
请管理员添加 Xicor X24645,X24325,X24165  谢谢!
版本:  V12.78  2025.1.19
T56编程器 :
Support: 37906(+150)
T48编程器 :
Support: 35138(+142)
TL866II 编程器 :
Support:18991(+75)
2.优化EMMC文件分析功能
3.修复已知缺陷
FM28V020 、8582  修复
ATMEGA8A  EEPROM Erase修复
Will T56 adapters fit T76?
Hello             No updates from a certain date, now all focus is on T76. But you can dow ...
Albano.Matos 发表于 2025-1-3 23:38
And what would be an alternative provider's page?
替代提供商的页面是什么?
Seria bueno que esta pagina sea mejor implementada con otros idiomas.
It would be nice if this page was better implemented with other languages.
如果这个页面能用其他语言更好地实现就好了。
Where are the updates?
版本:  V12.67  2024.6.15
admin 发表于 2024-6-15 10:47
It has been
more than 6
months
since the last
to
see a new
version
with a lot
of
new
chips
and
new
features.
Please add support for Swissbit emmc SFEM4096B1EA1TO-I-GE-121-STD
Test 发表于 2024-8-14 02:12
Please add programming support for the AT89S4051 microcontroller, or show instructions so that the user can add it as a custom chip to your software for the T48 device programmer.
Thank you!
回复 113# Igor
2024-7-17 23:50
2024-7-17 19:13
Reply 1# admin
Ответить 106# администратору
2.工具栏中载入待写入文件
T56编程器 :
Support: 37756(+105)
T48编程器 :
Support: 34996(+86)
TL866II 编程器 :
Support:18916(+26)
2.新增:
ZB25Qxxx
XM25RU128C
D27C011
等芯片
3.修复已知缺陷
TMS27C240  修复
AK6440AM AF修正
修正其他已知BUG
版本:  V12.66  2024.2.5
T56编程器 :
Support: 37651(+158)
T48编程器 :
Support: 34910(+120)
TL866II 编程器 :
Support:18890(+65)
2.新增:SPI 系列1.2V芯片(T56)
等芯片
3.修复已知缺陷
mokia 发表于 2023-11-28 01:13
回复 103# love_edition
回复 102# Albano.Matos
2024-1-12 16:00
2024-1-12 12:47
2024-1-12 12:47
Why are there no updates?
请添加支持 WELTREND WT61P8**
回复 86# admin
能否增加EP310可编程逻辑芯片的支持?
I am having a problem with new version have had mini pro before these options are missing in Xgprog the config pages of 29f010
2023-10-27 03:44
2023-10-27 03:44
hello, please add PIC18F26Q10 and similar.
Dear Admin, please help!
