VGA_adpter DIY for T56 Programmer (VGA 适配器座)
PCB:
VGA_adapter.rar (560.46 KB)
注意:HDMI部分线路不可以手工连线制作适配器,HDMI信号工作频率达900MB/s,
      线路长短不同与线路交叉都无法使HDMI正常工作
VGA线:  最好使用15针全通线。
检查方法:PIN 4  9 10 11 12 15 必须有连通, 并且PIN4  9 11 12 15 不可以接地,
                PCB板上的VGA头为母头
HDMI线:可以使用通用的HDMI线
Note: Not to make a adapter by manually connection。
        HDMI signal working frequency up to 900mb / s,
       The HDMI can not work normally because of the different length of lines and the crossing of lines
The VGA head on PCB board is female.
用于串打打印与在线编程的VGA转USB 及 USB转耳机线,可以使用淘宝的的转接线。也可以按下图自制。多种线都能通用,软件能自动识别。
For serial printing and ISP on-line programming.
You can use  VGA to USB3.0/USB2.0 cable and VGA to headset cable  Sold on WEB.
It can also be made according to the following figure.
All kinds of lines can be recognized automatically by the software.
2020-12-12 16:26
Possible link on aliexpress.com
thank you very much
非常感谢你   :handshake
