Xgecu T56 not recognized
hello i have xgecu T56 programmer and won't be detected with Usb Cable only tested on many computer and same .
when i add 5V from psu extern the programmer work and test ok .??
any suggest for any parts need to be replaced or checked thank you in advance .
ps: firmware was updated to laste version and not resolve probleme .
think have 5v from the usb cable not working good
iam novice on electronics repair
regards
hello i have xgecu T56 programmer and won't be detected with Usb Cable only tested on many computer  ...
foulou0238 发表于 2023-5-28 01:26
As a User,
               already tested with a new cable? A spare cable still common in printers and scanners.If new cable works, but voltage in xgecu software is too low in the right pane welcome messages,
get a 'solid' cable to handle enough current to T56.
Hope it helps
hello mate,
thank you for your replay cable usb was tested on T48 programmer and working well .
i test 3 cables and 3 laptops but same probleme .
the programmer work only when 5v is connected from externel power supply .
if admin can give some solution i will be glade .
回复 3# foulou0238
2023-5-30 15:00
2023-5-30 15:00
Check this DC socket, it is possible that the contact is not working
hello Admin
Thank you so much for your message
and solution work great .
my programmer work again and connector solveed my issue .
many thanks boss you are awesome.
