FLASH Suppoort
Can you add support for the Sharp LH28F320STKD TSOP56,you have the LH28F320BJ TSOP48 hopefully its' very similar
Also a feature Request
is it possible to add a user memory configuration to allow us to add one off memories locally?
something like local.ini
Name, Package, Manufacture, Reference(this would be a memory or cpu that works similar to the one desired
then listing all pins
PIN Name, Number, Direction, type, level and anything else you need to make it work
you could have users submit these to also help you build the built-in support.
that or publish the DLL source to allow us to add our own.   i think the option above give you more control but either option works for a user
OK .it will be added soon.
Thank youI do have the datasheet if you have trouble finding it
Saw you added this to the .29 release, thank you I was able to confirm a bad flash and program a new one
Love the T56
