Support for 1-bit and 4-bit DRAM chip testing (e.g. 41464)
Hi there,
Are there any plans to support older 1-bit and 4-bit RAM chips like 4164/4464/41464 etc.?
I believe it will be pretty easy to implement this in TL-866ii software but super-useful for many users, as these chips still exist in many older devices that need a desperate repair.
Currently we need to go to dedicated hardware solutions just to check a couple of these or similar type of older RAM chips which is a waste of money and space. Implementing this on TL-866II/T56 will for sure boost your sales further!
I hope we can have some good news on this matter in one of your next versions of the XGPro software.
Thanks,
Ioannis
Hi there,
Are there any plans to support older 1-bit and 4-bit RAM chips like 4164/4464/41464 etc ...
sokratis 发表于 2022-4-6 08:30
Hello Ioannis,
                    Can you, please, post the address for those old chips datasheets? Nice to have, if available :-)
Maybe on section Logic Test--Thank users for enthusiastic sharing - XGecu Programmer Forums - Powered by Discuz!
would be better to post.
Regards
Hi Albano,
Here they are:
https://www.silicon-ark.co.uk/da ... xas-instruments.pdf
https://www.jameco.com/Jameco/Products/ProdDS/41574.pdf
Good suggestion, I will post it then also on the Logic Test section.
Cheers,
Ioannis
Hi Albano,
Here they are:
Good suggestion, I will post it then also on the Logic Test  ...
sokratis 发表于 2022-4-6 17:32
Hello Ioannis,  :-)
