Please enable ATmega16U2 (and variants) for TL866-II+
I noticed that the ATmega8U2, ATmega16U2, and ATmega32U2 MCUs are available for the T56 programmer, but are not currently enabled for the TL866-II+.
Can these MCUs please be enabled to be programmed with the TL866-II+ (both ZIF socket as well as ICSP port)? They should use the same programming algorithm as other Atmel AVR MCUs and should easily fit in the ZIF socket with the standard TQFP32 to DIP32 socket adapter. |
