P28F010 & AT28C010 not working anymore since firmware upgrade
I had to upgrade the firmware of my TL866II plus to 04.02.128 recently in order to continue to use my programmer and since then I can't read/write any Intel P28F010 and Atmel AT28C010 chips anymore. I also upgraded to the latest software version v11.81 (I even downgraded to see if that helps but no luck). Whatever I do (read/write/check), everything stays blank (FF FF). The Pin detection is OK, no errors on that one but the ID check gives errors because it stays blank (FF FF).
As far as I know, nothing changed from my side, same computer, same programmer, same USB cable, same chips (new and old ones), etc ...
Anyone else experiencing this issues or can help me to correct this ?
Thanks. |
