ERROR Pins reading EPROM AT27C1024 with Adapter
Hello, I need to read an EPROM AT27C1024 PLCC44, and I am using the PCC44-DIP40 adapter to do it.I have not problem with any other chips that I have read with my TL866II, but with this EPROM it is imposible.
I have check the pins of the adapter to verify every conections and it is ok.
When I try to read the EPROM AT27C1024, I select the chip in the ATMEL list, I pulse the READ button and the programmer detects error on all the pins of the chip. If I ignore the "Pin detection" then I read as a blank chip ($FF), but I know the chip is not blank.
Is it posible that there is an error in the reading/programming algorithm for this chip?
I need some help, pleasse.
Thankyou |
