Hello, I had same problem, but found a temporary solution, because market isn't the way we see it, but user oriented instead. If you try to find something to start, start at XGECU site in ALIexpress global site,
as i found my local one is a bit different....as a reference:
XGECU Official Store - Amazing prodcuts with exclusive discounts on AliExpress
Found the T56 adapters at
adapters for T56 - Shop Cheap adapters for T56 from China adapters for T56 Suppliers at XGECU Official Store on Aliexpress.com
Anyway, they don't offer a complete set, but small parts of it. I've ordered all adapters from there.
Anyway, some missing, and if you need some, to be sure they work, after installing the 11.30 version software,
searching for a a usual IC, or the IC adapter format, pressing device info tab, you can see it.
Some you can see it better, if pressing 'read' and then 'view adapter' pinout, this work offline, even without programmer.
Download Newest XGecu T56/TL866II software(下载最新软件) - 编程器使用与软件下载 - XGecu Programmer Forums - Powered by Discuz!
Most adapters from old machines are 40 or less pins, them most will be compatible, some don't...(looking in the diagram)
As an example, PLCC44 have 44 pins with T56, but is in the page, as a set ...if you already have the most of other PLCC adapters, try to contact them and order it separately.
As T56 still is growing chip support, most are sold in the Xgecu shop or other Shops, but some you can get now only from other dealers, like the QFN32 4x4 0.4 and 5x5 0.5...no big deal for me here.
Also you can add your own ICs not in the database, the the work is there for many already, my actual challenge, or request to add it, and hopefully wait to be supported, as 100s more every month or so
Hope it helps you, somehow :-) ( not trying confusing more, neither what i've expected, but it works ) |
