Please adding some prom N82s191CN3 , pal 20,16.., and uc.68705...many thanks
Hello !
I need to copy prom and pal and 68705p3..
I come from try to read Pal20R8 and PAL16r6..the Gal20V8 and PALCE20V8 is about pin to pin compatible..but unable to read...some pin
is hard coded not soft like 20V8 i think this why this is not readable with the GAL algorithme . Please could you add the read and write algorithme for this chips to the T56..
And the
N82s191CN3 or CY7C291A this same chip and this is very very simple one ..like a uv rom 2k 8bit but not exactly same pinout...
i have view the 27c16 type etc but not same pinout ce an Adress Ax line).
Many thanks .. perhaps i can help ? or perhaps could you give the trick to be able to add myself new chip algorithm to my T56.
Have a nice days.
Thanks again. |
