Feature: Check ID List
Would it be possible to add the Chip Ids within the software to identify/decode what the ID exactly is?
I example have a ST27C1001, which give me a check ID error and tell me that ID is 20 86. It means that the mask on the chip itself iswrong, but I was not able to identify what 20 86 is.
回复 1# teevee
   我之前就建议过做ID反查芯片的功能,但是得到回复是芯片ID太多,重复的也很多 无法精确反查。其实我认为ID反查还是很有用的 哪怕重复的ID较多,哪怕还有很多未知的厂家ID,但是依然可以将已知的,重复的芯片型号全部列出供使用者自行判断。该功能我认为十分有必要并且有用。
ID反查可以帮助识别一些二次丝印或丝印模糊的芯片
现有的数据库包含了几万个芯片但是却不提供ID反查 真的是资源浪费
回复 2# q519948746
   0x2086 is M27C1000 ,T56在下版本中会增加支持 ,
  它与M27C1001是不一样的,T866II Plus 引脚不是万能驱动,无法支持该芯片。
I'm not planning to get a T56 as i recently got the mini pro mk2.
Do you have a list of what the different ID has reference to?
