New Logic Test - 7419 Vector Table
The test was performed on the M74LS19P (hex Schmitt-Trigger inverters) chip from Mitsubishi.
7419 - Logic Vector.jpg (214.83 KB)
7419 - Logic Test.jpg (257.78 KB)
SN74LS19A, SN74LS24A.pdf (1.12 MB)
7419.lgc (2.11 KB)
回复 1# yovish
Thank you for your hard work.
It is recommended to add more vector test lines to detect short circuits between two adjacent logic cells.
As shown below:
It would be best to test all possible combinations of inputs and outputs on 6 gates (2^6=64), but I thought that's what you wanted, example of similar tests: 4009, 4069, 4584, 7404, 7405*, 7406*, 7414, 7416...
Creating tests with lots of lines is a pain in this release and you ignore various suggestions for improving the software ...
I am a supporter of full tests, but it seemed to me that it is about initial tests of the logic of the integrated circuit, and everyone can write exact and more precise tests by themselves.
Yes, otherwise I am attaching a full test of the 7419 (it can also be used for other integrated circuits of the same design)...
7419 (Full test) - Logic Vector.jpg (643.65 KB)
7419 (Full test) - Logic Test.jpg (302 KB)
7419 (Full test).lgc (3.56 KB)
回复 3# yovish
Yes, it is a lot of work to perform all the combined tests. Generally,  only the logic combination test of nearby pins is required..
