Cypress CY2292 support
Hello
would it be possible to add support for the Cypress CY2292 series chip?
The original chip requires Cypress FTG Programmer CY3670 and requires the CY3095 adapter, but based on what I see it doesn't seems to be really necessary. This chip is used on the console Sega Saturn pcb board revisions VA6 and up, there's VA13 made in china.
The datasheet:
https://www.infineon.com/dgdl/Infineon-CY2292_Three_PLL_General_Purpose_EPROM_Programmable_Clock_Generator-DataSheet-v14_00-EN.pdf
Thanks for your support
Best regards,
Link4Electronics
google translate:
你好
是否可以添加对 Cypress CY2292 系列芯片的支持?
原始芯片需要 Cypress FTG 编程器 CY3670 并需要 CY3095 适配器,但根据我的观察,这似乎并不是真正必要的。该芯片用于控制台 Sega Saturn PCB 板版本 VA6 及以上,中国制造的 VA13。
数据表:
感谢您的支持
此致,
Link4Electronics
