T48 Error with Atmel AT89S51
Hello! I purchased a T48 programmer. The software contains an obvious error
when used with Atmel AT89S51(4K), AT89S52(8K) (in any cases). The programmer works correctly with the AT89S53(12K)
. The AT89CXX programming algorithm is specified in S51 and S52, and it should be AT89SXX
as in AT89S53. As a result, it is impossible to work by regular tools with S51 and S52... Partial
work with S51 and S52 is possible through S53, but not all... programmer's software works correctly With Atmel AT89C51, and probably with the entire
AT89CXX series. How do I change the programming algorithm to use with S51 and S52? The microcontrollers are quite old, however my old programmer works fine with them |
