T48 Pro -> GAL22V10 not supported ?
Hi, GAL22V10 seems unwritable with my T48 Pro
(GAL16V8D works without any problem)
I also have a Xeltek Superpro 610P,
so I can easily compare...the same file AND the same chip had been used.
only difference ; it works on the Xeltek without any headache.
2 problems on Xprog:
1. If the file is larger than 4KB, I get a popup saying "Wrong file format..."
BUT it's only related to the header of the JED file!
If I cut the header data, the file is loaded without problem.
header trimmed and programmed/tested successfully on a GAL16V8
Looks like the xprog software is dumb and doesn't trim the header data itself, wow...
2. Unable to verify after prog.
Each time the verification fail.
The JED file is made by myself, compiled with WinCUPL (which is quite strict) and works perfectly on hardware, after being programmed without any errors on my Xeltek.
The problem is there, on the T48 (software or hardware problem?).
I tested few other GAL22V10 JED files and still the same problem.
Fail, fail, fail... And obviously it doesn't work on hardware
Really hope an update will appear soon to fix this problem.
Edit. Added JED file if you want to test ;)
Just in case, even in a little bit redundant, this file is working perfectly, but not on Xprog. |
